Cleaning pads on Irwin adjustable clamps
I'm a hobbyist and the yellow cushion pads on my Irwin adjustable clamps have starting leaving a mark on my projects. I was able to buy replacement pads for the larger "mini" size. The "micro" size, according to Irwin, are not available either direct from them and/or elsewhere. Irwin graciously sent me a small supply of a small pad, but alas, not for my model. Has anyone tried cleaning these pads and if so, how? THANKS
What have you tried so far? If regular household cleaners don't work, I'd try denatured alcohol.... but just a little as it's possible it might slightly dissolve the plastic - the plastic will harden back up after the alcohol evaporates.
I haven't tried cleaning yet. They are old and pads are getting stiff and lack flexibility. I'm concerned with chemicals making them stiffer. My initial thought was buy replacement pads if possible. I have thought of trying to sand lightly but that might leave exposed "pores" on the surface of the pad..
Magic eraser.....my wife uses them to clean the plastic balls, balance pads, and weights and almost everything else at the gym. No damage and works well. Better than a spray cleaner.
A buddy of mine worked in the Home Depot tool rental area, and apparently they used WD-40 to clean just about everything.
You might have to do a two-step cleaning process. One step to remove the gunk, another step to remove the cleaning agent.
