Convert Side-Hinge Doors to Vertical-Hinge Doors On Cabinet
Old 11-07-12, 02:05 PM
P
I have a dual, half-height cabinet (like those that are usually installed above a refrigerator) in my garage. I would like to remount the doors so they are hinged at the top and when open, will stay open until somebody closes them.
What kind of hardware should I look for? Again, I'd like to be able to swing the doors up about 110 degrees and have them somehow latch in place.
Old 11-07-12, 04:00 PM
XSleeper's Avatar
Received 714 Votes on 661 Posts
If your doors are thick enough to be bored for a 35mm euro cup hinge, and 75 is enough, I'd probably use these.
Otherwise, if you really need it to open about 110, and want something a little spendy, these would do the trick. You would need to add a mounting block behind the face frame for these hinges to mount on. Also, mounting plates w/ screws do not come with the hinges and must be ordered separately.
If you wanted to google other options, just look for "overhead cabinet hinges".
Old 11-07-12, 05:00 PM
D
