closet door tracks
Old 01-03-13, 09:12 PM
W
closet door tracks
I have a laundry room with double bifold doors. Does anyone know if there is a track assy that will let the doors roll on each side to a 90 degree turn to let them open into the laundry room instead of folding on the outside? Thanks
Old 01-04-13, 04:34 AM
czizzi's Avatar
Received 14 Votes on 12 Posts
Switch the two doors using the current track and brackets. It will flip the hinges to the opposite side of the door and they will open into the laundry room. You will need to add a knob to assist it closing on the hall side.
Old 01-04-13, 05:37 PM
W
did you ever see an entertainment center that has doors that enclose the tv area and slide open and curve into the unit along side the tv. that is how I want the doors to open
Old 01-04-13, 07:27 PM
XSleeper's Avatar
Received 714 Votes on 661 Posts
Here's a link to the installation instructions for one style of armoire style pivot door slide. you will notice they have a maximum size recommendation (I'm guessing that what you'd like to do will exceed their recommendation) and it would not be possible to use this style of pocket door in conjunction with a bifold door.
I'm also guessing you wouldn't want to dish out the kind of money that you'd be talking about in order to try this sort of thing. The hardware alone would cost a small fortune. Then multiply that by 2 for the 2nd door.
Old 01-06-13, 08:34 AM
W
closet sliders
XSleeper thanks for the info. I'm glad somebody knows what I was talking about.
