threaded rod hanger that mounts between joists?
Old 03-20-13, 03:11 AM
T
can anyone help me find a threaded rod hanger that mounts between joists?
Old 03-20-13, 04:06 AM
chandler's Avatar
Received 6 Votes on 6 Posts
There'll be no "hanger" that can safely span the distance and still be rigid enough to hold a load. Best bet is to frame between the joists and run the rod through the framing. What is the load? How much does it weigh? Will there be additional weight once it is installed? Will there be inherent movement of the load?
