shortest wood screw
Received 0 Votes
shortest wood screw
I need really short wood screws for a small projects what's the shortest wood screws on the market?
Why a wood screw? What type of head do you want, wide, countersunk, pan? And what thickness and materials are you using? A sheet metal type of screw comes to mind as the smallest I've used, 1/4".
Bud
Bud
I concur with Bud. If you want a short screw into wood a sheet-metal screw is your best choice. Truth is, unless I am fastening two pieces of wood together a sheet-metal screw is my first choice into wood.
Received 0 Votes
Allright here it is It's to fasten those stupid dividers in one of those aluminum tool case Aluminum Tool Case with Strap | Canadian Tire I bought some L brackets but all the screws I can find at Home Depot are too long and go through the case I even put washer but same thing I can find really short machine screws but no wood screws that short
The real problem is the dividers in the case. I had one and gave up trying to use it very quickly.. The dividers just flex too much to stay in place. You might try 1/4" Masonite as dividers but you almost have to add 1/2" inch plywood to the sides to hold them.
