Joint choice on a box.
Received 0 Votes
Hi Everyone,
I'm designing a stand for my pc monitor at the moment, essentially it will be a box, and i'm curious about which type of joint to use, im torn at the moment between using a dowel joint or a dovetail joint.
I have quite a limited knowledge on woodworking, so dovetails would provide a big challenge, one which im not sure I even have the tools to complete.
I figured a dowel is do-able, but then I didnt know if that would make it unstable in which case it would make a terrible stand.
For reference, i'm hoping to make it 45cmx20cmx20cm, I don't know whether that changes anything.
So can someone shed some light on this for me please.
Received 0 Votes
Received 0 Votes
@marksr - thanks, and I have no clue, I need the box to be hollow with space inside, how thick do you think it should be? and as for type again I have no clue.
@joecaption1 - thanks for that link, i'll definitely take a look at that, and am I allowed to put pictures on the forum? I wasn't sure if I was, i'll upload a picture as soon as I get home from work, unfortunately that'll be about three hours yet.
Received 0 Votes
It's hard to make suggestions without knowing what tools you have at hand or have access to. What type of monitor do you have? I'm guessing it's a flat panel so it's not very heavy. Will the box be utilitarian or do you want it to be polished desk accessory that is visible to people sitting across from your desk?
A dovetail is attractive and strong but difficult to cut by hand without practice and very good tools. Dovetail jigs are fussy and not worth the setup time for one item. If you have a router I would suggest dovetail "keys" that give the decorative look but are easy to accomplish. A couple ways to do it:
Router table:
http://www.woodsmithshop.com/downloa...etail-keys.pdf
Router jig:
Strong, Good-Looking Mitered Boxes | Woodsmith Tips
Router table:
Router jig:
I would probably go with the pocket screws but I own a Kreg system already.
I think just about anything is going to be fine as long as you use a decent thickness of material, a monitor stand doesn't have to handle much weight so I think how it looks may be an important factor in what you do.
