3mm snap ring?
Received 0 Votes
3mm snap ring?
Hi, I need to repair an item and I need a stainless steel 3mm snap ring and washer. Do you have any idea where I could go to ask for one or two? Big box stores do not even carry such small size... any "creative" idea would be appreciated
Received 0 Votes
Unless your willing to buy a box of them, your going to be super lucky to find a stainless steel one.
Someplace that repairs power tools may have some that small, just not in stainless.
Received 0 Votes
The piece belongs to a Swiss Army water jug and it's part of the mechanism to pour more water. This part will be in contact, or submerged, with drinking water. I tried to look online even for full boxes, but I haven't found stainless steel ones. Do you think printers use stainless steel hardware Gunguy54? joecaption1, where do I buy a box of those?
In the link below..... Graingers has the snap rings. I don't know if they will sell to just anyone online. To buy in the stores you need an account.
GRAINGER Retain Ring, Ext, Dia 3mm, PK 10 - Retaining Rings - 5DA32|DE-2.3SA
Here's a whole boatload for less. Not sure of the quality.
100pcs 3mm Stainless Steel E Clip Snap Ring Circlip | eBay
Washers too. Also found 3mm washers there too.
Flat Washer A4 Stainless Steel Plain Fits M3 ID 3 2mm OD 7mm PK 100 | eBay
Received 0 Votes
Thank PJmax, I am looking for the type of retaining ring that has the two holes for the pliers and makes almost a 360 degrees contact. I will search again online starting from your pointers, thanks!
I think those are called circlip or retaining ring snap rings. No where near as many venders of this style in metric. I did find several large commercial supply companies but the lot size was gigantic. One is below.
Try searching for "3mm stainless steel retaining snap rings"
American Ring and Tool - Specializing in snap rings
