Best Threaded Insert for ABS Plastic
Old 10-14-13, 10:27 AM
I'm looking for the best low-volume and cost effective threaded inserts to install into ABS plastic. I'm going into production with a product, so low volume would mean ~100-200 inserts per day.
I am currently using press-fit inserts, but they are a real pain to install by hand (usually I have to apply heat to fully install them).
I'm also considering using EZ-loc self-tapping inserts. Does anyone have experience using these in plastic -- does it work? EZ-loc only advertises them for wood, which is why I'm not sure.
One other option would be to use thermoplastic inserts. I'm not really sure about these though -- can they simply be installed with a soldering iron?
Any help is greatly appreciated.
Thanks,
Austin
Old 10-14-13, 11:48 AM
W
Received 27 Votes on 25 Posts
Inserts
What size inserts are we talking about?
Old 10-14-13, 03:03 PM
Inserts
Pretty small. Here's a link to the press-fit inserts I'm currently using:
Item No: EZ-600 [Head-Type Press Insert]
Old 10-15-13, 12:31 AM
Received 1,417 Votes on 1,310 Posts
It looks like the EZ Locs would work in plastic. May require a drop of Locktite though.
The smallest size I've seen available is 4-40.
The ones you are using is the best insert for what you're doing.
All American Products - E-LOK THREAD INSERTS
Old 10-15-13, 10:10 AM
Insert
Ok. Do you think it's ok to pinch the tabs/fins together (1) to make inserting the insert manually easier and (2) to minimize the amount of heat I need to apply to the insert. My thought process there is the more I can press the insert in by hand and less by using a soldering iron, less melted plastic will accumulate around the insert (in the hole and near the head of the insert).
Old 10-15-13, 10:42 PM
You should be able to pinch the tabs together slightly for easier insertion. You just need to make sure the screw you are using is long enough to re-open those tabs.
