Wheel hub
Received 0 Votes
Wheel hub
Hi, I have built a custom cart made out of wood. I initially mounted small casters but I needed bigger wheels, so I bought a couple of 10" wheels that are normally used for hand trucks.
I am now lost on how to create a decent hub for those two wheels. I would rather not have a full axle as the distance between the two wheels is almost 5 feet.
This wheel hub will basically need to be attached or go through to a 4x4 pressure-treated post. I could reinforce the other side with a piece of metal. Any other advice? I spent a lot of time at Home Depot and on the Internet but I haven't really found something that would just work. Strange, it seems such an easy thing to do...
Received 0 Votes
You are perfectly right. The cart is at home, I will take a picture ASAP. But in fact, think you weed to put a wheel hub to a vertical 4x4 post. The wheels I got is this one: 10" Pneumatic Tire
Get some 5/8 threaded rod. Drill a hole through post and put rod through it. Will have to cut rod to length and use either washers on inside of wheel or find spacer, Double nut both ends or nuts will back off, Don't over tighten.
Received 0 Votes
Little late now but I never would have bought air filled tires, solid only. Some cheap or free one's off an old lawn mower would have worked.
You will soon see those cheap Chinese tires will not hold air for long and the bench will not be as stable.
I would not use treaded rod. A simple solid one piece steel rod, some cotter pins and washers is all you need to mount the wheels.
Picture how a wheel kit works on a generator.
The threaded rod as Pugsl mentioned is probably the easiest since you mentioned not wanting to run a solid axle all the way across. You'll want a nut & large washer on both sides so you can really tighten it squeezing the wood framing in between. It's not the best way to do a cart but it's about the easiest and best way to work with what you've already got.
If your wheel has an offset hub you can probably just slide it on the threaded rod with the convex (sticking out) side facing your frame. Then put two nuts on the outside. Run the first in until it touches the bearing then back it off a half a turn. Hold the first nut with a wrench then run a second nut up to it and tighten while making sure to not let the first nut turn. You do NOT want the nuts squeezing or putting side pressure on the bearing. If the wheel can move side to side a tiny bit that's OK. If your wheel has a centered hub you will need to install nuts, a bunch of washer or a piece of tubing cut to length to hold the wheel off so it does not rub on the frame.
Received 0 Votes
Most threaded rod is grade 2. Not very strong.
A shoulder bolt would work better.
shoulder bolt | eBay
Received 0 Votes
joecaption1, I have bought those tires because they were 3.99 each and I need to move the cart on some gravel and grass before it can reach its place on the flat concrete. I can afford to fill them with the compressor whenever I need to!
Oh, I like the idea of rod and cotter pins, it's how hand trucks do, even if they use a full axle. But I do not know a drill press, and even if I had it it wouldn't be the simplest to drill the pin holes... any suggestion there?
If you go with a shoulder bolt you'll probably need one 8-9" long; 3.5" to go through the vertical 4x4 plus 1.5" for the side 2x4 add 2.375" for the wheel's hub then an extra inch for a nut & washers. With a shoulder bolt you won't be able to tighten the bolt to the frame independent of the wheel so you have to be careful to not squeeze the wheel. The bearings are rather tender to side loads.
