Porch Rails
Old 02-28-01, 02:40 PM
Arrow
I need to know what is the best thing to use to fasten posts for porch rails to a brick front porch. I really want them to be strong. I have used those metal post brackets before and they are not that strong.\
Any help appreciated.
[email protected]
Old 03-05-01, 08:40 PM
josh1
posts
if i understand you correctly you wish to attach wooden posts ? to the brick front of your porch
If you are going to cut a notch into the posts and overhang them over the side you can drill holes with a masonry bit 2 per post should do it
Then use metal lag shields in the brick holes and secure the posts with zinc plated or galvanized 1/2" lag bolts 2 or 3 inches long should be plenty of holding power
PS wrap a piece of masking tape around your masonry bit at the desired depth so you know when to stop
hope this helps------josh
