Drawer slides for bathroom vanity
Received 0 Votes
I have been going nuts trying to find slides that have the two prongs on the end to connect to the rear bracket (the prongs slide on horizontally to the bracket at rear of vanity interior). My vanity is open on the interior so the only points of drawer attachment is rear bracket and one screw in front. All the slides I find are to be mounted to a flat surface on a horizontal. I need to find slides that "float" with only those two points of attachment mentioned. Please advise!
A picture of the back of your cabinet showing these drawer glide brackets would really help. Most of the ones you find in stores will be the "universal" type that may not mount exactly the same way but you can usually make them work.
Received 0 Votes
Here are pics of the glides I am looking for as well as my cabinet interior. You can see the mounting bracket in the rear of cabinet. Hope this helps you help me. Basically, I need to find this style of glides. (or a reasonable substitution without ripping out the vanity from the wall)
Thanks!
Thanks!
Your picture of the back drawer socket is pretty fuzzy. Is this it?
32-115 Rear Drawer Track Bracket, Grass : SWISCO.com
Or this?
Drawer track brackets about 15 inches : SWISCO.com
Or this?
