Screw Size Identification
I need to replace a small screw that I drilled out of a keyless entry fob for my vehicle (it was stripped). It is a flathead metric screw and is about the same size as a 2-56. In fact a 2-56 will just start to grab but then seize up. What is the equivalent metric size to a 2-56? I measured the diameter of the screw using my calipers and it is about 0.075" (1.9 mm) with about 55-60 threads per inch.
I used to own a mobile electronics store and had people stopping by all the time for odd screws and parts.
if you have a store like that..... give them a try. Otherwise I have no idea where you could find just one or two screws of that size.
