Make a bolt be tighter in a coupling nut?
Old 07-07-14, 11:47 AM
Hi,
I have a basketball rim that attaches to a plate on the backboard with a coupling nut. A heavy duty spring is then placed over the coupling nut and a bolt Is inserted into the coupling nut through the back part of the rim and turned in order to level the rim.
The issue is when the ball is hitting the rim, the coupling nut moves a tiny bit and after a few days, the rim is no longer level.
I can turn the bolt with my fingers so I think it is too loose.
Is there something I can do to make the bolt be a bit tighter in the coupling nut so it does not move as easily when the ball hits the rim?
thanks
Old 07-07-14, 12:04 PM
A
Received 67 Votes on 61 Posts
I would try a jam nut. A regular nut would suffice, but, depending on how much thread is exposed, an actual jam nut will be thinner. Tighten the two against each other, and see how it holds. Or, if the coupler is threaded tight to the board, maybe all you need is a lock washer.
Old 07-07-14, 12:08 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Or some locktite or similar thread locker.
Old 07-07-14, 12:32 PM
Thanks for the suggestions.
Let me see if I can get a picture of what the rim with the coupling nut in the rim looks like
Old 07-07-14, 05:40 PM
The attached doc shows the rim and the bolt that goes through the back lower right pic
If I apply Loctite to the threads would this prevent me from removing the bolt at a later time?
Old 07-07-14, 05:53 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
Loctite Will make the bolt harder to remove but will not stop it from coming out when you want get it out. should fix your problem.
Old 07-07-14, 06:19 PM
G
Received 2 Votes on 2 Posts
Just be sure to use the "blue Loctite" for future removal or adjustment. The red version is forever - or almost forever.
Old 07-07-14, 06:23 PM
Gunguy45's Avatar
Super Moderator
Yes, red is for studs and would require heat for removal.
Old 07-08-14, 11:00 AM
thanks for the info
i will check at our local ace or Lowes for the blue loctite
