Removing tight srews in Double Glazing Friction Hinges
Old 07-28-14, 11:32 AM
B
I need to replace the hinges on a double glazed window but am unable to turn a couple of the screws (Stainless?) which hold the track to the plastic frame.
I tried using WD40, Tapping the screw with a hammer, tightening the screw by hand and all failed.
If I drill out the screw head, how do I remove the screw?
I would welcome any advice please.
Brendan
Old 07-28-14, 01:49 PM
W
Received 32 Votes on 29 Posts
Screws
I would use an impact driver.
Old 07-28-14, 02:53 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
You can also use a small hammer and tap, tap, tap, on the end of a screwdriver while turning. Poor mans impact driver.
Old 07-28-14, 03:50 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Welcome to the forums! If all else fails and you cam out the screw head, you may be forced to use a screw extractor such as this. Ontel Speed Out Speed Out Screw Extractor (4-Piece)-1000264 at The Home Depot
BTW what DNA family are you from? 7A?
