Anyone Know What These Are?
Old 09-07-14, 07:39 AM
D
Wire Brush - Both are Made of Iron, I Believe.
Thanks.
Old 09-07-14, 07:56 AM
XSleeper's Avatar
Received 792 Votes on 729 Posts
Looks like the sort of thing a chimney sweep would use. Is there black soot on them?
Old 09-07-14, 08:07 AM
Received 1,343 Votes on 1,241 Posts
Welcome to the forums.
The one on the left looks like it slides together or apart. Almost looks like a regulator or governor from an old piece of equipment.
Old 09-07-14, 08:21 AM
XSleeper's Avatar
Oil well or irrigation well equipment?
Old 09-07-14, 08:45 AM
D
No Soot.
They have both been cleaned I think.
Thanks for the help.
Old 09-07-14, 08:48 AM
D
The one on the left says - collicott (?) improved on one end.
Old 09-07-14, 09:04 AM
Could be..... like a cutting blade maybe.
Old 09-07-14, 09:12 AM
Received 1 Vote on 1 Post
My thiughts were chimney cleaning tools, or tools to cut through clogs/roots in drain waste pipes. They look like they are designed to spin, and possibl (?) expand in width/diameter.
Old 09-07-14, 11:11 AM
F
Received 36 Votes on 28 Posts
Yeah, I know what they are. They are pretty old examples of boiler tube cleaners. They are for use inside of the water tubes and would connect to an air or water turbine mounted on a hose with a steel spring outside reinforcement. Centrifugal force throws the arms outward where they either cut or knock off the scale that forms from boiling the water.
Not at all a fun job.
Old 09-07-14, 11:44 AM
oldmrjim's Avatar
100% correct. I am surprised someone else knew that. Have not seen them in more than 20 years.
Old 09-07-14, 11:55 AM
D
Thanks!
Thanks for all the replies. Ebay here I come...
Old 09-07-14, 10:44 PM
F
I'm an old fart, I worked for an electric utility when in my early twenties and became familiar with tube turbines from the wrong end.
