PVC pipe adjuster piece
Old 12-14-14, 11:22 PM
A
BSD
Hi I am looking for a piece to add to a pvc pipe. Like I want a pipe and add an a piece to it that would allow me to slide it up and down the pipe and tighten and loosen it to hold certain position heights on the pipe. My intention would be to create a sort of camera slider and I would put it on the the piece that adjusts up and down the pipe. Does such an adjusting piece exist?
Old 12-14-14, 11:53 PM
Received 1,476 Votes on 1,364 Posts
Welcome to the forums.
You want to make a telescopic pole. It sounds easier than it is. It might be easier to find a telescopic pole you could modify.
There are fitting like in the picture below but they are only available in a limited number of sizes. The biggest problem with PVC is that consecutive sizes don't fit tight inside each other.
Name:  compression fitting.jpg
Old 12-15-14, 03:51 AM
chandler's Avatar
Received 6 Votes on 6 Posts
Crude at best, but I use 3/4" and 1/2" EMT conduit with a sequence of 1/4" holes drilled at 2" intervals along the 1/2" piece and a hole drilled through the 3/4" piece. Using a 1/2" delrin pin and cotter pin, I can set the height of my hunting tarp cover at different heights. Very strong. I knurl over the 1/2" end to where it will fit in a tarp grommet. I have no idea what a camera slider is, to it may not work.
