What glue to Temporarily prevent screws undoing fom vibrations?
Old 07-20-15, 01:14 AM
T
The small screws I'm looking at have a small globe of clear glue holding them in place so they wont undo, The glue has small air bubbles in it.
You can easily chip away at it with a screw driver & it all comes off, while not letting the screws undo at all. Which is needed to open & maintain the device.
Just wondering what types of glue would I use? Can't be something like epoxy as that requires hard sanding & chiselling to get off.
thanks
Old 07-20-15, 01:19 AM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Nail polish works pretty well, esp for small screws.
Old 07-20-15, 05:24 AM
V
Received 1 Vote on 1 Post
You've already considered the different variations of Loctite ?
Old 07-20-15, 05:27 AM
Norm201's Avatar
Received 317 Votes on 284 Posts
The nail polish trick Vic speaks of is very god. I use this on my glasses. Never fails.
Old 07-21-15, 03:53 AM
T
As far as I can tell, Locktite 435 sounds like what I should use.
Does any know if it can be chipped away & easy to remove?
thanks
Old 07-21-15, 04:51 AM
Received 383 Votes on 339 Posts
Locktite goes on the threads.
Old 07-21-15, 08:24 AM
G
I did a quick search and couldn't find any information on releasing Locktite 435. It's a cyanoacrylate adhesive ("superglue") and appears to be intended to be permanent.
Loctite 242 (blue) has always been my go-to threadlocker where being able to later remove the screws is needed. 262 (red) is stronger but needs heat to release.
Nail polish on the screw head (or Glyptal for you old-timers) doesn't have much hold but is fine for where minimal resistance to loosening is acceptable.
Old 07-21-15, 02:19 PM
Received 85 Votes on 80 Posts
What are these screws on?
Just can not imagine why if they where intended to be removed by some DIY to just maintain the "device" they would have glued them in place.
Old 07-22-15, 09:34 AM
G
I've seen this dozens of times on electronic equipment. The older it is, or if military, the more common. EVERY TV tuner back in the rotary-dial days had Glyptol on the adjustments--even though TVs were never intended to experience mechanical vibrations.
Even today I occasionally see a dab of clear acrylic glue on screw heads but thread locker is far more common now.
Old 07-22-15, 02:50 PM
chandler's Avatar
Received 6 Votes on 6 Posts
I likewise use Locktite 242 on the threads. It holds up keeping scopes on high powered rifles from shaking loose, and that's quite a whollop. In the event of needing removal, it can be done.
