Garage Ceiling Storage Door Fastening
Received 0 Votes
Hi, I have a metal structure affixed to my ceiling in my garage for storage. One end has been drywalled which has created a closed back for my ceiling storage. The front end is open and i wish to make some type of wood open upward c door like in open upward kitchen cabinets and i need it to stay up. The ceiling storage is 6 meters wide so i would not mind splitting into 3 or 4 doors.
I need to know what type of hinge i can use attach one part to the ceiling and one part to a piece of plywood that will be my door.
Any suggestions welcome
Thanks in advance
Thanks in advance
Received 0 Votes
Will go down and fetch a pic later.
As for your other concern.. The walls and ceiling are made of solid concrete. There is only a drywall partition to split my garage in 2 but nothing will be attached to it.
Will take a pic and photoshop some more info into it thanks
Look up 'gas spring shocks' like they use for topper doors on trucks. Just replaced one of mine, very easy.
You'd have to take all the measurements, weight etc. but it would work just fine.
Hinges
I would use a pair of door hinges like these:
Everbilt 3-1/2 in. x 3-1/2 in. x 5/8 in. Radius Satin Nickel Door Hinge-14984 - The Home Depot
You will need longer screws to fasten to the ceiling.
