Need help finding slotted metal plate
Old 09-04-15, 05:36 PM
Hello All,
I am trying to create a moveable "arm" that is able to move back and forth and rotate etc. In order to do this I need what i thought was a simple piece. I've attached a picture of my crude attempt to make this but I need something mroe professional! Basically a square piece of metal with two lines going down the middle. I walked around Home Depot for hours and can't seem to find something like this! I am really hoping someone might have an idea! Picture attached. Thanks so much!
Size is about 2 inches by 1 inch or so. Looking for something pretty thin (a few millimeters)
Old 09-04-15, 06:14 PM
Rough Rooster's Avatar
Received 6 Votes on 6 Posts
Some brands of heavy duty suspenders have something similar that is used to adjust suspender length.
One of those might work for you.
RR
Old 09-04-15, 06:21 PM
C
Received 2 Votes on 2 Posts
Not exactly what you want, but if the size is right you could cut off the extra hole:
Slotted Brackets | EMIcorp.com
Old 09-04-15, 06:44 PM
Thank you both! I appreciate the quick turnaround
Old 09-04-15, 07:33 PM
Norm201's Avatar
Received 253 Votes on 227 Posts
Any adjustable car roof rack strap or belt safety strap will have the save thing. Some auto battery hold down straps also have this.
Old 09-04-15, 09:21 PM
Received 1,165 Votes on 1,080 Posts
It looks similar to plates I used in the past. Try googling "car alarm pin switch bracket".
