Concrete Anchor Specs
Received 0 Votes
Who can specification this anchor? I show the dimensions in this picture. I need type and standard for this anchor. This anchor will insert in concrete.
Best regards,
HAJDIN BEHLULI
I can't give specifics. You need to give us specifics. What are you fastening and how thick and heavy?
As a general rule use these as a guide:
It's been my experience that different manufactures specs will vary between lengths and diameters but will all be very close to the same.
- Smaller, lighter weight objects can be fastened using 3/16” and 1/4" diameter fasteners.
- Medium weight items will require 3/8”, 1/2" or 5/8” diameter fasteners.
- Heavy objects call for the use of 5/8”, 3/4” or 1” diameter fasteners.
Anchor
Nowhere in the diagram does it say millimeters. I know that millimeters is a good assumption, but we know about assumptions. I should think someone wanting specifications would be more detail oriented. Just my 2 cents.
