Splice wood posts
Old 11-29-15, 03:19 PM
D
Splice wood posts
I am splicing two 4x4 posts together with a lap joint. I want to use bolts through the joint but am looking for some type of bolt so that there isn't a nut, washer and stick through on the one side. I'd like it to look like two bolt heads on each side. Any fasteners like that?
This isn't really a structural connection. I want to extend the height of a gate post to stretch a header across the top to get it plumb. The other side is my garage. The extension will be about 18".
Thanks for you help.
Old 11-29-15, 03:30 PM
XSleeper's Avatar
Received 900 Votes on 826 Posts
Sounds like you are describing a sex bolt. Or maybe a carriage bolt on one side and a 1/4x20 barrel nut on the opposite side.
You would probably need to use 3 or 4 of them through the joint to immobilize it or it will wiggle.
Old 11-29-15, 03:36 PM
Received 99 Votes on 87 Posts
Just use a Forster bit to counter bore a hole as big as the washer is so the nut and waster are counter sunk.
Old 11-29-15, 03:45 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
T-nuts can be used on one side and the bolt head (hex) recessed on the other. You don't need an expensive Forstner bit. A spade bit works fine. Drill your recess first then use the the concave center left by the spade bit to center your hole for the bolt shank.
Old 11-29-15, 04:06 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Binding posts. Remove the male bolt and replace with a pan head bolt of the appropriate length/size/thread. I am sure you can find them cheaper. The Hillman Group 3/8 in. x 2-1/16 in. Stainless-Steel Architectural Binding Post (6-Pack)-44789 - The Home Depot
Old 12-02-15, 04:29 PM
D
Thanks all. I found these. Unfortunately the don't make one yet for a nominal 4x4. Not till early next year.
Timber Bolts (56649, 56650, 56651, 56652)
