maul handle replacement
Got this old Craftsman brand 6-lb splitting maul that I wouldn't mind trying to restore to usable condition. Obviously needs handle replaced. The new model Craftsman splitting mauls like this (that I've seen online) don't have the wooden handle. I'm just wondering how I could maybe acquire a new wooden handle that will fit this maul just right. Seems to be a pretty limited selection of replacement handles these days at the home centers , hardware store where I live anyway. It would need to fit just right of course. Are all these type handles for axes, mauls like this, etc, pretty much the same standard configuration and pretty much any generic handle about the right size will fit, or not? I compared the top of the handle (showing through at the top of the maul head) with the top of a handle showing though the top of an axe head I have, and the shape/size seems not exactly the same. What's a good source for finding the appropriate replacement handle for this maul, or will it be too much trouble to bother with? Plus of course if I can get the handle replaced I'll clean up the rust off the maul head and sharpen it. But just worried about being able to get the right handle first. Any comments appreciated.
looks like there is a couple different styles for splitting mauls but you could probably find a generic one that would work.
Striking tool hickory wood replacement handles; axe handle, hammer handle
as per is it worth fixing probably, but wood handles do eventually break especially if you happen to miss and hit the handle witch appears to be what happened to this one. though but for splitting wood would much rather use a Fiskars x27 than a traditional maul.
They sell handle protectors (rubber collars) for that. I've missed a few and never an issue, the rubber absorbs the blow, though it does give your arms a bit of a vibration.
Looks like you need the one at the bottom of the list.
The one second up from the bottom of the list (the number 5200) is described as for "D.B. eye types" and I don't know what that means. The length mentioned is 32" to 36" and my old one is a 34" so maybe that's the more appropriate replacement?
Measuring the top of the eye hole of my maul head, I get a length of 2 7/16" inches, and the widest part of the oval measures 15/16".
So at this point I cannot be sure which of those two on the bottom of the list would work best. Any further comment/advice appreciated. thanks
Call the dealer and give them the measurements. They will help you choose the correct one. A couple of inches extra handle length is a good thing.
