Fastener advice needed for installing metal bracket to basement wall
I purchased this exercise bracket but have not installed it because it didn't come with any information or fasteners. Here's the link.
I want to install it on my basement wall which is cinder-block (I assume rebar reinforced with concrete, since it's been standing for over 50 years and still standing.)
There are two brackets - total height 6' and total weight 10lbs. It calls for 6 fasteners and the openings for the fasteners are 1/2" diameter. It is intended to be installed vertically, the first bar from floor to 3' and the second from 3' to 6'.
What I'm concerned about is providing support for whatever weight is applied during exercise. The exercise bands are practically weightless, but the largest weight output at maximum stress of the bands themselves is 25lb. But how much weight will be added to load by both the body weight of the exerciser and the maximum stress of the exercise? Let's figure for body weight up to 250lbs.
The reason why I ask this question is that I was looking on Home Depot for possible fasteners. On one product, I don't remember which, a user asked if the fastener in question would hold a 100lb plaque securely onto a wall. A product representative gave a complicated answer about the weight capacity including stress from pressure or movement being 850lbs and, therefore, the fasteners would support a passive weight of 100lbs.
That's when I began thinking of all the complications in considering how to install these bars.
Hoping this is an easier issue for someone to solve than it has been for me/
Of blocks are hollow you may be able to drill between the webs and use toggle bolts. If solid you could use expansion bolts.
I'd drill a couple of test holes to see.
