Wrong hinge & strike plate
Received 0 Votes
My builder insists these are the correct hinge and strike-plate fir this door....The only place I have seen these hinges used (hinges with the alignment tabs) are for mounting a wood door to a metal frame...
Do these look like the correct components for this door?
I most often see hinges like that on entry doors, both wood and steel. I always thought the protruding tab helps strengthen the hinge/door against being kicked or pushed in.
The "tabs" on the hinges are what I think is a poor attempt to replicate a security stud. The idea is that if the hinge pins are removed, the leafs of the hinge won't slide past each other. But that "pimple" of a stud is easily overcome.
The extended-lip strike is often required when the inside of the door frame isn't flush with the inside of the wall (as in thicker walls) or with thicker casings. Below are strikes with lips from 1.5" to 4".
