Bent hinge
Old 03-15-19, 04:05 AM
A
Bent hinge
I have a top bent hinge that will not let my cabinet stay closed (please see pictures below). Should I replace it or can it be repaired?
Old 03-15-19, 04:12 AM
Norm201's Avatar
Received 356 Votes on 321 Posts
Not worth fixing. Buy a new one.
Old 03-15-19, 04:13 AM
pugsl's Avatar
Received 76 Votes on 69 Posts
Take hinge off and put on a hard flat surface and hammer straight. You could google hinges and try to find a replacement.
Old 03-15-19, 05:20 AM
A
Received 72 Votes on 65 Posts
I would give straightening it a shot first. If you have a good bench vise, open it so that both ends are supported on the jaws with the crowned part of the pin up, lay a block of wood on it so you don't mar the surface, and give it a rap or two with a hammer. Or you could do the same thing with a couple of blocks on a bench. You might get it on just a flat surface, but I'd prefer to for it to be able to spring just past center and come back for something like that.
