Name of Missing Inserts to Attach Bedframe
Old 06-05-19, 08:22 PM
B
Hi everyone - first post, please pardon mistakes. I attempted posting 3 pictures, but can't tell if uploading worked.
First picture shows side pieces of roommate's just-acquired, disassembled bedframe.
Second picture shows edge of side piece, where the long screws go into the side from the headboard, and the circular depressions where the matching metal inserts should go; each insert should have 2 holes in it, so that a screw can pass through the insert. The insert holds the screw and provides more strength than just the wood of the side piece.
Third picture shows measurement of the insert holes, which are 1 3/8 inches in diameter.
What are these inserts called?? I need to order them, so that the frame doesn't fall apart. Any suggestions welcome!
Last edited by BarrettSun; 06-05-19 at 08:29 PM. Reason: Add Pictures... didn't work the secone time. Yes, I am clicking on Go Advanced.
Old 06-05-19, 08:41 PM
Received 98 Votes on 86 Posts
Looks like a cam lock bolt system to me.
Old 06-05-19, 08:56 PM
XSleeper's Avatar
Received 847 Votes on 776 Posts
Yes, Google 35mm cam bolt and dowel.
https://woodworker.com/swirl-cam-set...su-128-825.asp
Old 06-05-19, 10:20 PM
B
Awesome!
Ok, I found cam, dowel and nut on hardware.com for about $4/set. Frame needs 8 sets. Cheaper to buy 10 with volume discount, total cost $29.60.
Is that reasonable? Is there a better place to buy from?
Old 06-05-19, 10:54 PM
I've never had to buy them, they've always come with whatever I was building so I don't know that I can judge a good price. That said, that's a small enough amount of money that it seems likely it wouldn't be worth your time to look for a better price.
Old 06-06-19, 12:23 AM
B
Ok, went ahead and bought them. Thanks, gang.
