Can anyone identify this?
Hi Folks,
Anyone seen this part before (pictures attached)? It works like an anchor to hold the AC vent up in the ceiling. My home is from the 1970s, so I'm not sure if they make parts like this anymore. I'm trying to source another one, but not even sure what it's called or where I might find a part like it. Thank you
mk3947 voted this post useful.
Welcome. Things like that are not totally unique in that you could find any number of somewhat similar clips with various vents, bathroom fans, etc., but it is unique in that it was used by one manufacturer for their products and anything you happen across would be close but not quite. Long story short, it's not worth spending any time trying to find an exact duplicate. You might poke through the miscellaneous bins and drawers at your local hardware or big box and find something that you could make work, or you might make one from something like a piece of step flashing, bent into shape, and a hole drilled in it to start a sheet metal screw. That's what I would do.
BD111 voted this post useful.
Agreed, these look more like a make-it-yourself project -
1- a narrow "eye punch" to open the hole for the screw
2- a pair of sheet metal pliers, aka "duckbill pliers" for bending.the shape.
3)- then find the right sort of metal to make the clips.
How flexible is the metal?
I'd look around for scrap metal- scrap A/C ductwork, an old computer case, the drip pins or doors from a discarded gas grill,
and then try bending some to see which sort of metal works best.
Hi, does that duct push up? If so try placing a couple pieces of strapping up there next to the duct, secure it in place with drywall screws under the diffuser then secure the diffuser to it , here is a crewed pic.
Thank for the sketch and the idea -- what is strapping? (I'm no professional). The duct does push up; the duct and the diffuser are attached to one another. So ideally if I can make another anchor like the one I have already, I can make the whole piece push up flush against the ceiling. Also, I don't think I can find drywall screws small enough to fit my diffuser. Those two holes where the screws go in the diffuser are tiny tiny, it took me forever to find screws the same size in hardware store.
Hi, strapping is 1X 3 lumber or any other pieces of lumber you have around, you should be able to use the screws you have to secure the diffuser through the drywall into the board above which could be secured with drywall screws or even some construction adhesive.
Geo
Geo
