Half-threaded screw bolt pin?
Old 07-10-19, 04:46 PM
B
I'm trying to identify and locate this part for purchase. It is from a pressure washer's pressure sensor and screws in by the plunger/spring section in the 1st image. You can see the head snapped off and it was an absolute nightmare to remove...
Appreciate any help.
Images
Old 07-10-19, 04:49 PM
XSleeper's Avatar
Received 846 Votes on 775 Posts
Pretty sure you need to find the schematic for that power washer and order it from them. Brand, model #, etc. All would be helpful to know.
Old 07-10-19, 05:01 PM
B
They'll sell me the entire assembly for the low sale price of only $89.00 (currently on sale from $159.00). Purchasing the screw alone was not an option.
I politely refused.
Old 07-10-19, 05:02 PM
P
Received 783 Votes on 720 Posts
I would call it a flat head machine screw. If it was just holding the inspection cover in place then the shank probably isn't too important and you might be able to use a screw threaded all the way which might be easier to find.
The first step is to measure the diameter (accurately) or test screw it into some nuts of known size to find out if it's English or Metric threads and what size. Then measuring the length is easy.
Old 07-10-19, 05:05 PM
Received 1,399 Votes on 1,296 Posts
Welcome to the forums.
This is an electric pressure washer ?
I've never seen an electrical pressure switch on one before.
