Metal Stud and articulating arm
Old 07-22-19, 05:10 PM
Hi am looking at installing a 20-30" tv with an articulating mount that pulls out away from the wall. The mount has two holes that are meant to go in one stud. I was thinking I would use toggle bolts through the steel stud.
Any thoughts on if this is a good idea?
Thanks!
Old 07-22-19, 10:58 PM
Received 257 Votes on 242 Posts
Welcome to the forums.
No..... it's not a good idea.
You need to spread the weight out. If it was a standard non moving wall mount..... you could wing it with toggle bolts. In your case you'd need to screw a board to two metal studs and attach to that board.
Old 07-23-19, 07:39 PM
Thanks for the input. It's meant to be mounted on one stud, is similar to. Otherwise will have to rethink.
Old 07-23-19, 08:25 PM
XSleeper's Avatar
Received 162 Votes on 152 Posts
Something like that really ought to have a solid wood reinforcement put inside the metal stud. If you don't mind doing some drywall repair you could cut open the wall and go that route.
Old 07-24-19, 06:10 PM
Will do, seems to be a no brainer.
Thanks everyone!
