Drawer pulls: help with center to center measurement
Received 0 Votes
This is a stupid question, but what size are these drawer pulls? I'm trying to find replacements, but don't see any for the measurements I'm getting. Thanks.
If your tape was held in the same position for both pictures I see 2 1/16" between holes but that's an odd size. It might even be metric. It's easier to measure with the screws removed. Then you can measure from the edge of one hole to the same edge on the other hole.
The most common pull sizes are....................
3”
4”
96mm = 3.77" (roughly 3-3/4")
128mm = 5"
160mm = 6-1/4"
3”
4”
128mm = 5"
160mm = 6-1/4"
Doorman2722, Norm201 voted this post useful.
Received 0 Votes
I'm so sorry, I have no idea why the pictures are so big on here or how to delete my old pictures. Here it is on the 1" mark.
The picture system is a little tricky. You either need to take smaller pictures or resize them before posting them. The ideal size for this site is 600x600 max which usually yields a file size of approx 75-100kb. Your three pictures were over 3000x2000 and 3.2mb each. The board will accept them and resize them but it eats into your allotment of 10mb storage. I typically run thru every thread and check on pictures. I resize them if they are too large.
