Kitchen Cabinet Hinges
Hi, I need to replace a couple of these cabinet hinges and am not sure which one to buy. Here's a photo of the hinge:
And a little more zoomed out so the cabinet is visible,
This one looks pretty close but I am not sure about overlay, frame vs not frame: https://smile.amazon.com/Concealed-K...dp/B01CSC4XRS/
Will this one work?
Thanks for your help!
Will this one work?
I do not see a face frame in your picture so you want non frame.
Why not remove the hinge and go to a lumber yard to get an exact match.
In order to know what hinge and plate to order we need to know the amount of overlay (distance the door lays over the face frame when the door is shut) on the face frame side of the door (hinge side) as well as the measurement from the side of the cabinet where the plate mounts to the inside edge of the face frame. It looks like maybe 1 1/4" but that measurement is critical. It would also help to know the distance from the edge of the cabinet door to the edge of the cup (in mm).
