Putting Back Prong-Type Sliding Roller Wardrobe Track
Received 0 Votes
Hi all,
The mirror on one of the two sliding frames came off as did one side of the bottom track. The bottom ones are pronged vs wheels (the top parts of the frames are wheels). How can I get the bottom ones on? They have two prongs in the front and one in the back. I have attached pictures of the attached and unattached sides.
Thanks!
Jerry
Thanks!
Jerry
If that doesn't seem to work, you will need to take it off the rollers by grasping the panel on both sides, then lift up. Tilt the top away and rest the nylon guides in the bottom track. Then tip the panel back up until its vertical. Then once its vertical, lift the entire panel up until the rollers are back on the top track.
