Can not adjust Hinges
Old 03-05-20, 10:05 AM
P
Every since I brought this house this cabinet has been a problem.I would like to replace the hinge below. Would like a hinge that I would like to be able to adjust this cabinet Any ideas?
Old 03-05-20, 11:09 AM
XSleeper's Avatar
Received 714 Votes on 661 Posts
The hinge you have is 3 way adjustable so not sure what else you need.
Old 03-05-20, 02:25 PM
Norm201's Avatar
Received 254 Votes on 228 Posts
Agree with X, that hinge should give all the adjustment you need. Unless the spring is broken. Then replace it.
Old 03-05-20, 02:40 PM
XSleeper's Avatar
And if the overlay (left to right) is wrong you can get a different mounting plate. They come in a variety of thicknesses if you need to move it farther to the right than your adjustment allows.
