Latch for a large access panel
Old 04-05-20, 06:58 PM
I have large access panel (3'4') in the wall of my finished basement that doesn't have a latch so the 'door' sits slightly ajar. I can't find a cheap/small latch besides a 2" bolt latch which seems overkill. It's essentially just a cut-away of the sheet rock with hinges that allows the door to swing open but no latch to stay closed. Any ideas?
Old 04-05-20, 07:09 PM
XSleeper's Avatar
Received 938 Votes on 856 Posts
Magnetic catch, snap catch... ball catch... eye hook... quite a few options. You could also put a screen door spring on it. Hard to imagine exactly what you have without seeing it.
A lot of hinges snap closed, so different hinges could be an option as well.
Old 04-05-20, 07:11 PM
All require a handle except the eye hook, right?
I'll take a pic when I get a minute. It's a 2' X 4 or 5' cut out of the sheet rock with 3 hinges and it doesn't slow all the way and sits 1" ajar and drives me nuts. I can use a striker but than need a handle which makes it more obvious. Maybe a tiny eye hook will be the cleanest.
Old 04-06-20, 03:15 AM
Received 164 Votes on 151 Posts
You could use a recessed door handle.
Old 04-06-20, 03:28 AM
pugsl's Avatar
Received 76 Votes on 69 Posts
Magnetic latch used on medicine cabinets. Have then in all hardware stores. You just push door in slightly and latch releases.
Old 04-07-20, 10:41 AM
Magnetic latch. I literally couldn't think of the word to search for. Thanks.
Old 04-07-20, 10:53 AM
XSleeper's Avatar
Yeah it was the first 2 words in my reply. LOL
https://images.app.goo.gl/X2BZ9GvtWA4TGb828
Old 04-07-20, 11:00 AM
You all helped me
im still not handy but getting better
