Fastener Name
Received 0 Votes
Fastener Name
Sorry for being an idiot on a fastener. What would you recommend for quickly temporarily attaching a 2 foot wall to another 2 foot wood wall (it might be 3ftX3ft).
As you can see it is going to be a box and I will be using a 1x4 wood and I will have 4 temporary walls. Each corner I would like to join the 2 together walls, but easily take it a part. Normally, I would nail everything together, but each wall will have weight and my wife would not be able to pickup the full box, but she would be able to move an individual small wall.
What fastener would type would be used that for easy installation and removal. Maybe something like a pin and 2 per corner. This will be used outdoors. Also I am hoping there is something that is not expensive.
Thank you for your help.
Jeff
Jeff
Welcome to the forums.
A lot of members reading but no responses.
It's a little difficult understanding what it is you are doing. I understand the four walls but then you say box. A box would have a top and bottom which would change things.
Holding the corners together with hinges and removable hinge pins is a great idea.
