Needing Exterior Toggle Bolt
Old 05-05-20, 12:51 PM
I need to attach a bracket to sheet metal with a toggle-type bolt. This is an outside project and I'm not finding any toggle bolts that will work outside. Can someone point me to something that may work.
Thanks,
Sam
Old 05-05-20, 01:14 PM
Received 398 Votes on 354 Posts
What makes you think a steel toggle bolt won't work outside? What is the application? I'd assume the toggle would be protected from the weather and the head could always be painted.
Old 05-05-20, 01:21 PM
XSleeper's Avatar
Received 895 Votes on 821 Posts
Google Stainless Steel toggle bolt. Lots of options.
Old 05-05-20, 02:37 PM
T
Snaptoggle by Toggler is a good option. Stainless steel or brass I think with plastic extending out from the wall. I could send you a box....
https://toggler.com/products/snaptog...steel-channels
Old 05-05-20, 02:51 PM
Thanks for the quick responses. To answer marksr, I was just thinking the zinc coated toggle bolts that you find everywhere were for indoors. Home Depot's site labels them as "interior". I'll look up the other options. Only the screw head would be exposed and get wet and I could slap a little silicone on the heads. You will not be able to see the heads.
