Is a Hole Saw the right tool?
Old 07-04-20, 09:54 PM
JoeBronx's Avatar
I have limited work space so Im planning to mount a medium sized vise on a 3 &1/2 slab of wood which I can clamp/anchor to the table when needed for use. I plan to use a Hole Saw to cut 4, 2 deep recessed holes into the underside of the wood to keep the lock bolts and nuts that hold the vise above flat on the table. Is a Hole Saw what I need? Im not very experienced so Id be grateful for any advice or suggestions you Forum sisters and brothers offer! Thanks!
Old 07-04-20, 10:10 PM
XSleeper's Avatar
Received 582 Votes on 535 Posts
No, what you would want is called a forstner bit. It will make a clean, flat bottomed hole partway through the wood. A hole saw would cut the perimeter of the hole but you would need to chisel out the waste that was left once you drilled as deep as you needed.
A spade bit would also work, but it will leave a deeper hole in the center where the pilot bit spins.
Pilot Dane voted this post useful.
Old 07-05-20, 11:17 AM
JoeBronx's Avatar
Many Thanks Xsleeper! I'm glad my description was clear enough for you to understand.
I'm immediately checking out the Forstner Bit.
