fix padlock?
Old 08-13-20, 05:22 PM
sgull's Avatar
Received 4 Votes on 3 Posts
fix padlock?
When this happens to padlocks like this is there any fix?
Old 08-14-20, 02:19 AM
Received 398 Votes on 354 Posts
While you might could fix it, I'd replace it. Doesn't make sense to use a padlock that has already failed once.
Old 08-14-20, 06:07 AM
Norm201's Avatar
Received 339 Votes on 305 Posts
I bet Master will replace that. Try just for fun.
sgull voted this post useful.
Old 08-14-20, 06:11 AM
Seems like I had one that did that [don't remember the brand] and I was able to push it back together and used it until I got a replacement.
Old 08-14-20, 08:13 AM
sgull's Avatar
I've experienced this exact thing happening with several of these same locks periodically over a number of years where we use them at my workplace on some outdoor shed doors. They are unprotected and get wet from the rain and even freeze up during the cold wintertime requiring some heat from a torch so can use the key to unlock. Sometimes you can push them back together and they work for little while but never long. Usually observe some obvious rust inside, have tried using rust-busting type penetrating oil to lubricate inside hoping that might fix whatever it is that fails inside, but it doesn't. Perhaps the exposure to the elements over time as described is too much for the mechanism to endure; these relatively inexpensive locks are probably prone to this type of failure if not "treated right".
Edit: Went to the Master Lock website. It says to ensure long life and trouble-free operation of padlock in harsh environments, to clean and lubricate it every three to six months. Says to use Master's PTFE lock lubricant. I didn't do any of that.
