using rare earth magnet to locate property pins?
Old 08-30-20, 09:40 AM
K
I am trying to locate the pins on the corners of my lot in prep for fence installation. I have found the 3 across the back and need to find the front 2 corners now. I am trying to use a metal detector and having some luck. I am close to one but haven't found it just yet.
I am wondering if a rare earth magnet on the end of a string would work since it is a metal stake that is used for the pins?
Any thoughts on this?
Old 08-30-20, 10:19 AM
Received 1,473 Votes on 1,361 Posts
Depending on how deep the pin is below ground it may work but it will be clumsy swinging around on the end of a string.
I've always used a metal detector to find ones I'm looking for.
Old 08-30-20, 10:20 AM
P
Received 852 Votes on 787 Posts
Magnets range is so short it would be almost useless locating a surveying stake. A metal detector is a much better tool for the job. If you can't find the stake it is possible that it is no longer in the ground.
