Help identifying screw
Old 10-02-20, 06:57 PM
K
Does anyone know what type of screw this is? I went to Home Depot and Lowes and they didn't have anything with a phillips head that's also hexagonal. I tried searching online but I have no idea what it's called.
Old 10-02-20, 07:06 PM
B
Received 1 Vote on 1 Post
It's a small lag bolt with a phillips head drive as well. Not sure that I could come up with a name....but...
https://ever-hardware.com/lag-bolts-...-hex-head.html
Brad
Old 10-02-20, 10:42 PM
Received 1,399 Votes on 1,296 Posts
Not sure there is a technical name for them but they're in the link below.
Hex lag screws
Old 10-02-20, 10:50 PM
XSleeper's Avatar
Received 846 Votes on 775 Posts
Old 10-03-20, 06:11 AM
B
Received 104 Votes on 91 Posts
Why do you need both a Phillips and hex drive capability on the same screw? It's obvious somebody makes them but it is not common because it increases cost compared to a single drive screw.
Old 10-03-20, 11:41 AM
P
Received 783 Votes on 720 Posts
Hardware like that is often sold as part of "kits". If you buy a play set or bunk bed you might have a screw like that in the hardware kit. Nobody really stocks or uses hardware like that as you found in the hardware isle at your home centers. It's just a convenience feature the manufacturer included in their hardware packet. If you need another one I'd buy a traditional hex head lag screw but it won't have the Philips on the head.
Old 10-03-20, 12:11 PM
K
Well, I tried to install a paddleboard mount and it didn't work but i stripped the screw I was trying to replace the screw so I can return it.
Old 10-03-20, 12:17 PM
Maybe we can offer help with the mounting. Post a picture for us if you'd like help.
Old 10-03-20, 05:08 PM
K
The only place I could store vertically I hit metal. I had no idea what it was so decided not to put it there. I actually made one out of PVC and did a different type of mount (to store vertically). I guess I'll try to find another use for the mount. It was $50 though!
