Where can I get one of these?
Old 11-14-20, 02:46 PM
L
This was on my golf cart and I need more but I donít know what it is called or how to install. Itís a threaded insert for my side mirror. Thank you!
Old 11-14-20, 03:08 PM
Received 1,180 Votes on 1,093 Posts
I've always called them nutserts. They're also called rivet nuts.
You need to know what size you need. They basically come in all different thread sizes.
Old 11-14-20, 03:11 PM
P
Received 681 Votes on 628 Posts
I call them riv-nuts. They are installed sort of like a pop rivet and small ones can use a normal pop rivet squeezer. If you don't want to buy the big squeezer (that looks like pruning loppers) there is a much less expensive one that uses a bolt and a metal block.
Marq1's Avatar
Received 394 Votes on 368 Posts
They are riv-nuts or rivet-nuts, kind of like a rivet in how they are installed!
You will find them all here!
https://www.mcmaster.com/rivnuts/
Old 11-14-20, 03:13 PM
L
Thanks everyone! I appreciate you!
