Tap and die questions
Old 01-28-21, 06:10 PM
N
Question Tap and die questions
So I own a dumb bell but I can't find one of the screws to secure the weights. It turns out it uses an M16 1.0 45 MM. I managed to find a M16 2.0 45 MM relatively cheap but obviously that doesn't do me much good. I got a tap and die set for Christmas but have never used one before. Can I reduce the thread count required by the dumb bell and maintain the M16 size?
Old 01-28-21, 09:59 PM
C
Received 8 Votes on 7 Posts
In metric world, M16 means the diameter of the bolt is 16mm, and the 1.0 is the distance between threads in millimeters. I've never tried to re-thread a bolt like that- i suspect you'd have a tough time, but it might work. If you have the proper die you might buy a long M16 bolt like the one in the link: cut the 2.0 threads off and then cut 1.0 threads in the blank part. Good luck, let us know how it goes!
Dave
https://www.homedepot.com/p/M16-2-0-...2128/204273698
NewbieSoSueMe voted this post useful.
Old 01-29-21, 01:06 AM
Marq1's Avatar
Received 489 Votes on 453 Posts
Can you do it yes but you will be cutting out a lot of the major diameter thread material making the thread a weak joint.
Those fine thread metrics are not used much so unless you have a dedicated fastener retailer like Fastenal around you wont find them at the local hardware store. And even then they will probably have to order.
Might check eBay!
Old 01-29-21, 06:06 AM
P
Received 872 Votes on 802 Posts
No, I would not try to convert from a coarse to a fine thread. There won't be much material left to hold. You would need to go to the next size larger bolt or... just get the correct bolt. And I don't think your thread spec is correct. I think your M16 is actually 1.5 pitch and not 1.0 pitch. If you search for that you should be able to find what you need.
Old 01-29-21, 09:02 AM
Received 398 Votes on 354 Posts
Also the tap and dies sets most of us diyers have are more suited for chasing threads [cleaning them up] than actually cutting new threads.
Old 01-29-21, 01:45 PM
N
Yeah I also thought about converting it to a 3/4 size bolt. Which is the next biggest US sized bolt. If I can get the right size tap I will attempt it but it will be awhile.
Old 01-29-21, 02:39 PM
B
Received 111 Votes on 97 Posts
Have you checked at an auto parts store? Most have a large supply of metrics.
