Best way to remove almost stripped screw
Old 06-19-21, 02:28 PM
H
What would be the best way to remove this almost stripped screw from the bottom of my refrigerator door? It protrudes about 1/2 inch, but I cant get a grip on it with a pliers or grippy ratchet set, and the slot seems about to be completely stripped and wont provide enough torque to unscrew?
Thanks much
Old 06-19-21, 03:53 PM
Marq1's Avatar
Received 1,138 Upvotes on 1,032 Posts
Vise grips!!!!!!!!!!!!!!!!!!!
Old 06-19-21, 04:50 PM
D
Received 202 Upvotes on 163 Posts
OK, let me ask....... is it the head that's almost stripped...... or is it the threads, that's almost stripped?
Old 06-20-21, 06:04 AM
B
Received 13 Upvotes on 9 Posts
Buy a 6 or 8 inch pipe wrench.
Also works great on a rounded brake bleeder.
Old 06-20-21, 08:18 AM
Received 3,485 Upvotes on 3,128 Posts
Only one tool..... Vise Grips.
ThisOldMan voted this post useful.
Old 06-20-21, 05:46 PM
H
It is the head that is almost stripped
Old 06-20-21, 06:28 PM
D
Get some needle nose vice grips
https://www.homedepot.com/p/Stanley-...E&gclsrc=aw.ds
Old 06-21-21, 06:10 AM
W
Received 60 Upvotes on 52 Posts
Apply the vise grips perpendicular to the screw shaft to get a better grip on the rim of the screw head.
Old 06-21-21, 09:43 AM
F
Received 48 Upvotes on 37 Posts
First of all, make sure you have a Philips screwdriver that was a very good bit. Not all bits are equally "grippy." I have an ancient Stanley that's my go-to because I know from experience it tends to 'bite' when other drivers don't.
Then use the rubber band trick. Be sure to press harder than you're twisting.
