What's this thing called?
Old 11-17-21, 12:12 PM
C
Received 5 Upvotes on 5 Posts
My linear motion ball bearing slide block did not come with this little knob. I don't know what it's called. I need to purchase a replacement for mine but I don't know the name. This side hole here is used to be grease in there, I think.
Top Answer
11-17-21, 12:24 PM
I Mullins
I Mullins is offline
Received 35 Upvotes on 29 Posts
It's a grease fitting, sometimes called a Zerk fitting. Available at any auto parts store.
Take the bearing block with you if you can to make sure the threads are correct.
If your bearing is going to get a lot of use or is in a dirty environment, you may also want a grease gun and the appropriate kind of grease. For light use, maybe you'll never need it.
Old 11-17-21, 12:20 PM
jatco's Avatar
Received 1 Upvote on 1 Post
I did a Google image search and found it to be a 'pillow block' ..
"What is pillow block used for?
Pillow block bearings are actually housings that have a bearing fitted into them. They are usually mounted in cleaner environments and are not meant to bear higher loads. The main application is to mount bearings safely with a stationary outer ring and a rotating inner ring.Oct. 6, 2016"
Old 11-17-21, 12:24 PM
I
bulova, Charlie2 voted this post useful.
Old 11-17-21, 12:36 PM
jatco's Avatar
Old 11-18-21, 05:02 AM
P
Received 1,956 Upvotes on 1,752 Posts
Be careful getting a grease fitting from your auto parts store. Most/all linear slide blocks like yours are imported and most have metric everything. If it's ANSI fitting it's likely either 1/4"-28 (straight thread) or 1/8" NPT (tapered thread). If it's metric you could have a BPSP or M6, M8 or M10...
Old 11-18-21, 05:34 AM
Norm201's Avatar
Received 694 Upvotes on 617 Posts
​​​​​​​What does BPSP stand for?
Old 11-18-21, 08:14 AM
P
You caught my mistake. It was supposed to be BSPT (British Standard Pipe Taper) which more common in Asia. It looks similar NPT but has a different thread pitch and different thread angle.
Norm201 voted this post useful.
Old 11-19-21, 08:19 AM
C
Thank you so much for all your help. Now I know what it's called and I'll take my sliding block to the store to make sure it actually fits.
