Robertson/square drive between R1 and R2?
Old 12-19-21, 10:03 AM
R
Received 2 Upvotes on 2 Posts
I have a Kraloy PVC conduit body and the cover has screws with a combination slotted and square drive.
I know these drive types have been around for a long time, but I recently tried a square drive R1 and it was too small and the R2 was too large. The R2 went in part way (they're tapered) but not enough to get a good grip.
What is the square drive that fits these screws?
Old 12-19-21, 10:11 AM
Received 3,480 Upvotes on 3,125 Posts
I thought it was a #2 bit.
Old 12-19-21, 10:12 AM
XSleeper's Avatar
Received 1,743 Upvotes on 1,567 Posts
If it's the head that I'm thinking you have, that's called Pozidrive. The proper bit is a Pozi bit.
Edit: oh, slotted. I see PJ's photo... yeah that should be S2.
Old 12-19-21, 10:16 AM
R
I thought a Pozidrive had four points like a Phillips. The screws I have only have two, like a flat blade screwdriver.
Old 12-19-21, 10:20 AM
XSleeper's Avatar
Yeah that's why I added the edit it when I saw the photo.
Old 12-20-21, 05:19 AM
B
Received 242 Upvotes on 215 Posts
As noted, the square in the screw head and drive bit are tapered. I doubt the screw manufacturers check every screw/drive bit for out of tolerance tapers so some defective make their way to the consumer. Take the #1 drive bit and grind away the tip until it fits without bottoming or grind the flats on a #2 drive bit until it fits and bottoms.
ruauu2 voted this post useful.
Old 12-20-21, 07:18 AM
W
Received 60 Upvotes on 52 Posts
Looks like an ECX.
