Getting seized set screw out
Old 01-19-22, 08:19 AM
B
Received 5 Upvotes on 2 Posts
This is for a restroom exhaust fan. The motor died and I have to get the blade off the shaft shown in the picture.
I’ve dowsed the screw with PB blaster a few times and let it sit overnight but it doesn’t seem to be budging.
might this be reverse thread?
Top Answer
01-27-22, 10:25 AM
beedoola
beedoola is offline
I finally got it. Pushed the Allen key almost to its limit but it popped loose!
Old 01-19-22, 08:26 AM
P
Received 1,851 Upvotes on 1,657 Posts
It should have a standard direction thread. Only use a high quality, sharp wrench and make sure it is seated as far in as it will go... and hope it breaks free. You can also try heating it with a torch.
Old 01-19-22, 10:17 AM
Marq1's Avatar
Received 1,144 Upvotes on 1,037 Posts
I just had a situation trying to get a set screw out of a single handle faucet.
Took about 5 days of a small shot of PB every day, 5th day it came right out, give it some time.
Good advice on the tool, a good, not cheap hex will seat better and prevent striping.
Old 01-20-22, 06:38 AM
R
Received 2 Upvotes on 2 Posts
It's very unlikely a reverse thread.
My father taught me an old trick - if you can't loosen a screw, tighten it. Then attempt to loosen it. That's worked for me many times over the years.
Also what Marq1 said - give it more time with the PB Blaster.
Old 01-20-22, 08:32 AM
Norm201's Avatar
Received 678 Upvotes on 601 Posts
I've used that trick on many occasions. Just enough to crack the corrosion. ​​​​​​​
Old 01-27-22, 10:25 AM
B
CircuitBreaker, Dixie2012, Marq1, Norm201 voted this post useful.
