Attaching to brick facing
Old 02-07-22, 12:14 PM
Norm201's Avatar
Received 674 Upvotes on 597 Posts
I just received a Ring Video Doorbell from the kids.
They provided a set of plastic anchors to attach to the brick. I never cared for those type of anchors. Any suggestion for a better way of attachment. Something that will prevent a thief from taking a putty knife or a screwdriver to pry it off the wall. If I was going into wood no problem, but these things are next to worthless.
Old 02-07-22, 12:44 PM
A
Hate to sound negative but I don't think there's any reasonable way to attach it to brick to keep a thief from prying it off. I just attached one to brick about 3-4 months ago and I used (2) plastic anchors at the top into the mortar joint.
Then I put a dab of caulk on the bottom rather than drill into the brick.
Old 02-07-22, 01:49 PM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
I have used these for years for anchoring small things to concrete. I think they would break the doorbell before they ever pried it out.
Anchor
Old 02-07-22, 07:44 PM
Tolyn Ironhand's Avatar
Received 705 Upvotes on 598 Posts
I recommend using Tapcons or some other concrete screw.
Norm201 voted this post useful.
Old 02-08-22, 09:53 AM
A
Those screws are No. 2 screws, IIRC. Not sure a tapcon or masonry screw comes that small.
Old 02-08-22, 01:21 PM
Norm201's Avatar
Hmm...good point.
AbleDog, You, bring up a point about screwing into the mortar vs the brick. I always thought that screwing into the brick is stronger than into the mortar.
Old 02-08-22, 02:53 PM
XSleeper's Avatar
You screw into the mortar because it is typically softer AND repairable. Once you drill into brick, that hole is there forever.
Old 02-08-22, 06:56 PM
Norm201's Avatar
I was under the impression that drilling into the brick was better and makes for a tighter fastener, just because mortar does tend to soften, and breakdown. As far as repairing goes, if I should have the need to remove the unit, I don't think two small holes will be an eyesore and they also can be filled in with colored cement. Or doe I need to be corrected?
Old 02-08-22, 06:58 PM
XSleeper's Avatar
You're a big boy, you can decide.
Old 02-08-22, 07:03 PM
Norm201's Avatar
Two schools of thought...
"Drilling into brick vs. ... Mortar is easier to drill through because it's a softer substance than brick and is also easier to patch or repair. Drilling into the mortar with a screw expansion plug or another fastener will cause the anchor's force to push against the intact bricks instead of expanding the material."
OR
"As a general rule, unless you're hanging something very light (just a pound or two),
always drill into brick. Mortar doesn't have the strength to hold much weight, and it deteriorates much faster than brick."
Considering the item, mortar will be the choice for this application.
XSleeper voted this post useful.
