Hello, I bought a new blade for my Saw-All. Been trimming bushes and small trees limbs. How do I get this plastic off? I haven't tried real hard as yet as the teeth are hard to hold to remove it. There's a rivet in the hole hold blade but hard to cut it away. Thanks.
Ok. Tried to to break the nub off with a utility knife but it wouldn't cut.(hard space age plastic?) I wanted to ask before putting it on my vise. Thought maybe there was a trick to it in these times. Thank you.
I got it. I put it on my vice and sawed off the nub. It took a minute, really hard plastic. Or could have pounded out the nub on my work counter. I was just thinking there might be a trick to it if there were no extra tools available. Thank you.
[h1]My wife claimed a Zinus table from one of these Facebook groups. Problem is, the previous owner took apart the table and lost the hardware.
I contacted Zinus to try to order replacement bolts but they said they don't sell separate hardware and claimed to not know the size of the bolts.
I found the user manual (link below) but it provides no info as to the size of the bolts. Does anyone by chance recognize what the bolt may be? Thank you.
[url]https://mans.io/files/viewer/1613801/1[/url][/h1]https://mans.io/item/zinus/hd-dt-f29
Hi, I have to install a defrost thermostat in the fridge, I don't have a Crimping tool to Crimp the butt connectors. I only have a wire cutter called "super Champ 11" can that be used as a crimping tool? Thanks
