in my 1st post that was an existing original hinge from another cabinet. these 2 pics are from the new hinge she bought and thought it was the same thing.you can see how the cabinet is not right. i looked at the link you sent but it seems like none have that single screw hole in the middle. isnt that important for an exact match
def have wrong ones but it does appear that centered screw is critical. even on the wrong one it fits 'right' on the door. the 3 holes ones just appear they wouldnt work
thanks also figured out the 3/8 means measure the edge. funny thing is used the old bathroom one to fix a broken kitchen hinge. just ordered 4 new satin for her bathroom so now i know more about hinges
Hi, I am looking to replace some silver washers with black washers (or possible blue colored ones if I can find them). I know almost nothing about this stuff lol, but my understanding is that these are finishing washers, aka countersunk washers. But there is one that's a little shorter-and-wider, and one that's a little taller-and-narrower. Pictures below. When I search for finishing washers, it seems like only the wider version comes up, and I need at least a couple of the narrow version in order to fit this project. I'm found "cone washers" that look closer to the narrow washer, but they aren't angled to fit a countersunk screw.
Is there a particular term that distinguishes these two types of washers?
[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1558x1504/img_9197_0f9d74ab915e564f98f4c722c98e166b2c4550c7.jpg[/img]
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1787x1765/img_9196_c2510369ef7074e3d947276fb2899dc9b4959bd2.jpg[/img]
Read More
I'm trying to repair a 1970-vintage blueprint cabinet at work. After looking it over it appears that two of the original drawers were swapped out with two drawers from another cabinet which used a different suspension system.
I believe that I can get these replaced drawers to work if I can find and install new drawer rollers to support the rear. The ones on the original drawers look to be 1" diameter with a 5/16" fine thread mounting stud. What are the other critical dimensions I'll need to provide? Attaching pics. ETA: Well, tried to attach. Doesn't seem possible on mobile.Read More
