Any non-bulky "clamp" to shorten the length of a strap?
Old 04-24-23, 10:34 AM
Received 4 Upvotes on 4 Posts
Lately, to save on costs, heavybags are being made with straps in lieu of traditional chains.
The problem is I can't shorten the straps like I can a chain.
Is there some sort of clamp that will allow me to fold up the strap and clamp it together so it's not so long?
Old 04-24-23, 11:20 AM
Received 1,231 Upvotes on 1,179 Posts
You could tie them in a knot.
Old 04-24-23, 01:50 PM
The bag will be moved around to different hangers (different heights) so the knots will have to be repeatedly undone.
Normally that wouldn't be an issue but since the weight of the bag combined with the pounding tends to tighten the knot more.
Old 04-24-23, 02:34 PM
P
Received 1,952 Upvotes on 1,748 Posts
Buy a bag that has chains or straps the length you want. Or, you can sew other attachment points into the straps or shorten the existing straps.
Old 04-24-23, 02:43 PM
the problem is that with the bag moving to different locations (as in facilities), the facilities have different ceiling heights so the adjustment of the strap length is frequent.
Old 04-24-23, 07:05 PM
XSleeper's Avatar
Received 1,812 Upvotes on 1,629 Posts
Twist them as much as you need to before you hang the bag. Twisting them will shorten their length. This is what you do with chains that are a little too long, such as when hooking up the safety chains on a Uhaul trailer.
